tommylarsen Friend
tommylarsen
- March 2014
April 1, 2014 at 7:30 pm #196357On iphone i do not get the responsive design, but a desktopview With all the modules showing, but they are all cut off on the right and bottom side.
the off canvas menu is not showing either.
On android I have a problem With the main menu, it is sticky when scrolling Down, but dissapears when i og to the top of the page again.
http://www.elicom.no for those who want to have a look.
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
April 1, 2014 at 7:42 pm #529054Hi,
Your site works fine on my android but unfortunately i couldn’t log on to your joomla backend to check if everything is updated.
Please verify that everything is updated and clear cache.Let me know if that helps
regards
Manos
tommylarsen Friendtommylarsen
- March 2014
April 1, 2014 at 7:45 pm #529055Hi again, I see I have forgotten a Capital letter in the password, just try the first letter in Capital.
I have one update I get an error on….
- February 2014
April 1, 2014 at 7:53 pm #529057Hi,
That was it i managed to log on to your joomla back end, please go to JoomlArt Extensions Manager -> Services Manager and enter your log on credentials so you can update everything. Make sure you create a full site backup prior to anything else.You will also notice that the version on your template is outdated so many of your problems might as well have been fixed by now.Let me know if that helps 🙂
Manos
1 user says Thank You to Manos for this useful post
- March 2014
April 1, 2014 at 8:25 pm #529060That fixed the problem on iphone yes, but if you load the page in an android you will see that the menu is not showing correct. It is not showing when you are at the top of the page, and when you scroll Down the menu appears, but With the standard logo behind my own…
And in portrait mode there is something happening With on emodule that gets on top of the masshead-module….Manos ModeratorManos
- February 2014
April 2, 2014 at 5:30 am #529128Hi,
I didn’t face any problems browsing your site using an Android Device can you please provide us with a screen shot or the page we can see the issue ?
Manos
- March 2014
April 3, 2014 at 6:51 pm #529409Here is a screenshot showing what I mean. You see the light menu With both logos…..
When I scroll up again the menu dissapears.
- February 2014
April 3, 2014 at 7:23 pm #529414Hi,
Add the following code to your custom.css file
<blockquote> @media (min-width: 980px)
.t3-mainnav.light-mainnav .logo-image a {
background-image: none!important;
}</blockquote>let me know if that solves the problem!
Manos
- March 2014
April 6, 2014 at 8:36 pm #529676Hello again, and thanks for all help. That fixed the problem With the double logo, but still the menu dissappears when scrolling back up to the top of the page.?
Only on a android tablet in landscape-mode.
- February 2014
April 6, 2014 at 9:02 pm #529681tommylarsen Friendtommylarsen
- March 2014
April 6, 2014 at 9:30 pm #529683You see it in portrait-mode. When I use my tablet in landscape this happens…..
AuthorPostsViewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 2 voices, and was last updated by tommylarsen 10 years, 8 months ago.
