  • mossaab Friend
    #926926
    Pankaj Sharma Moderator
    #926961
    Did u fixed the JA ACM issue ?
    Regarding layout problem , it my be due to low php values or wrong customization in layout files . I need to take look on your site for this problem , Kindly send your site Super user details via Private reply for this .
    mossaab Friend
    #927167
    #927210
    Your site admin details not working . Kindly check it again .
    mossaab Friend
    #927552
    can you try t again?
    thank you
    #927555
    its still same . Please check and provide working details .
    The layout issue is due to you have index.html file in site root folder. once you delete the file layout will work .
    mossaab Friend
    #927571
    #927971
    For the module position issue , You need to load the position name in menu options here : http://prntscr.com/b1jnby
    http://prntscr.com/b1jnkb
    Then try to publish position on news-home .
    Hope this helps .
    mossaab Friend
    #928066
    It works perfect, by the way i recogonized that i had the same problem with some other positions, is there any somehow to resolve that problem?
    Thank you
    #928093
    Add the other menu position in the same way ,
    Like for events use event-home . You can install the quickstart package on localhost with sample data to see each settings used in the demo site package and apply the same on your site .
    mossaab Friend
    #928150
    ok thanks a lot
This topic contains 11 replies, has 2 voices, and was last updated by  mossaab 8 years, 6 months ago.
The topic ‘problem with ja acm’ is closed to new replies.
