  • futureinprogress Friend
    #135593
    i’ve one problem with ja bulletin. In each article the date is 30.11.99
    This problem finish when i update un article, infact after having updated the article ja bulleting shows the right date
    Any suggestion?
    Thx
    Daria
    #280235
    Hi futureinprogress !
    This is strange problem , do you use quickstart package ?
    #280282
    yes i used quickstart package.
    I’m trying to setup a demo site to show the problem
    Daria
    —–update—-
    Here the demo site url
    http://193.201.171.127/~alyno/test/
    As you can see in the ja bulleting module an article called test has 30.11.99 date.
    If i update the article the problem desappears
    rokynrobyn Friend
    #351122
    I’m still having this problem. Has anyone found a fix?
    i still find any reasons causing this issue, pls access and re-edit those article, the problem will be fixed:)
    vectorinformatics Friend
    #353123
    Is there any solution to this problem? By re-editing the article, it does fix the issue, but why is the date 1999 in the first place? Do we have to publish articles twice in order to get the date correctly? Why is that? Any solution? We are experiencing trouble with this at http://fxtradelab.com
This topic contains 6 replies, has 5 voices, and was last updated by  vectorinformatics 14 years, 5 months ago.
