August 21, 2009 at 4:35 pm #143625
Hello Team,
Fine JA Bulletin Module by the fine template JA Nickel…
But I have a problem with pictures in it. When I will show a picture in the JA Bulletin Module, the text will not scoll at the right side. :((You can see my problem in the foto attachment
Hope anybody can help me, thanks 🙂
Melanie
August 25, 2009 at 5:54 am #315176Nobody can help me? :((
Saguaros ModeratorSaguaros
August 31, 2009 at 7:58 am #315796Hello Webkonzept!
Please give me your link , i will resolve this issue ok? 🙂
August 31, 2009 at 5:00 pm #315894Thanks, but I have now the Modul “Frontpage Modul” in action 😉 …it works as the same like JA Bulletin …
Byby Melanie
avekic Friendavekic
- July 2007
- 4 times in 1 posts
September 4, 2009 at 9:58 am #316341Hi,
I encountered same problem.
If it is possible, Melanie could you be more specific about that Frontpage Modul that you’re using instead of ja-bulletin?
Or if someone knows the solution for this…
BTW this thread is marked solved, but there is no actual solution..
avekic Friendavekic
- July 2007
September 4, 2009 at 1:14 pm #316356Please… does someone know how to fix this…
it’s pretty urgent to meavekic Friendavekic
- July 2007
September 7, 2009 at 12:14 pm #316670Still waiting….
jomlaart team, will someone even try to answer this?
September 7, 2009 at 12:18 pm #316673Hello avekic!
I’m very sorry for my delay, please give me your link site, your module has prolem with css ? i must to check in detail
September 7, 2009 at 12:22 pm #316675I ‘am waitting for your answer……………
avekic Friendavekic
- July 2007
September 7, 2009 at 12:23 pm #316676i sent you PM
check your inbox
(i don’t feel like sharing my user data here 😉
avekic Friendavekic
- July 2007
September 7, 2009 at 12:30 pm #316678you can contact me via skype.. i’m online
EDIT
I see you’ve solved it 😉
what was the problem (if it isn’t too complicated for short explanation)?
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 3 voices, and was last updated by Saguaros 15 years, 3 months ago.
Problem with JA Bulletin Module
