  • 2Patrick Friend
    #160424
    Problem With JA Cloris ( J 1.5 ) Quickstart Installation
    Just downloaded the JA Cloris Quickstart ( J 1.5 )
    However, during installation it does not allow the installation of sample content ( see attachment ) and final screen is :
    Notice: Undefined index: DBtype in /home/marretts/public_html/installation/installer/models/model.php on line 764
    Fatal error: Call to undefined method JException::getNullDate() in /home/marretts/public_html/installation/installer/helper.php on line 290
    Is there a problem with JA Cloris ( 1.5 ) Quickstart ?
    I have tried other JA Quickstarts before ( Teline etc ) but this is the 1st time I get an installation problem
    1. cant-install-sample-Joomla-quickstart-files
    2Patrick Friend
    #377694
    Previously I tried uploading with Cpanel.
    Today I tried with a FTP program
    Still the same problem.
    Can I get some assistance please
    panzerknacker Friend
    #377791
    Try this:
    1) Drop all table that were automatically created in the database after installation incomplete.
    2) Delete configulation.php form server and upload new configualtion.php with no text in configuration file (most people fail this step because rename file configuration.php-dist to configuration.php only but it is not blank page !!!!!)
    3) Change MOD at file configuration.php to 777 (you can change it basically by FTP or web control panel)
    4) Delete Installation folder and re-upload folder again.
    5) Try to run installation again.
    Phill Moderator
    #377793
    I’ve just tested the quickstart on my localhost and it all appears to install fine for me. If you are enabling the ftp layer during install please try without.
    2Patrick Friend
    #377899
    Hi guys
    Thanks for the tips
    I created a new configuration.php file and then deleted the old database and reinstalled JA Cloris.
    I still get the same errors including the ” XML response error @
    Please help
    Please help
    1. config-php-created
    2. XML-error
    2Patrick Friend
    #377900
    Hi guys
    Thanks for the tips
    Please help
    Please help</blockquote>
    #377966
    Try chmodding your /public_html folder or whatever folder you have it installed in to 755. It’s not the install package itself at fault here, I had no problem with it, it’s probably a rights issue.
    #378014
    Dear 2Patrick,
    It is strange that we tried but couls not get the issue occurred,maybe the problem is at your side 🙂
    2Patrick Friend
    #378033
    The whole public html folder and its contents are 755 ..apart from configuration.php which is 777
    I tried JA Cloris ( Joomla 1.6 ) but the installation went through.So there is something wrong with JA Cloris ( Joomla 1.5 version )
    #378060
    Dear 2Patrick,
    Can you let me know your hosting environment ? for example the php and mysql version etc..
    2Patrick Friend
    #378093
    The details are :
    Server: Localhost via UNIX socket
    Server version: 5.0.91-community-log
    Protocol version: 10
    MySQL charset: UTF-8 Unicode (utf8)
    Web server
    cpsrvd 11.28.83
    MySQL client version: 5.0.91
    PHP extension: mysql
    I am using Rochen Host
    2Patrick Friend
    #378534
    Hi Thanks
    I downloaded the JA Cloris again and this time the installation worked.Thanks
This topic contains 12 replies, has 4 voices, and was last updated by  2Patrick 13 years, 10 months ago.
