Viewing 15 posts - 1 through 15 (of 19 total)
  • franckyky Friend
    #168231
    Hi, (in advance : sorry for my english)
    I’ve several problems with JA Comment and JA Sidenews on my website (joomla1.7) My template is JA Methys
    With JA Comment
    Url : http://www.stephanequerioux.fr/index.php/jeune-et-con
    The component show “1 commentaire” but nothing appears….
    When I try to post a comment : nothing happens
    User 8 position :The module shows only the title of the article but not its contents.
    When I click on the title I have this error : Warning: Invalid argument supplied for foreach() in /htdocs/public/www/components/com_jacomment/views/comments/view.html.php on line 661
    With JA Sidenews
    Left position : This error appears : Warning: Invalid argument supplied for foreach() in /htdocs/public/www/templates/ja_methys/html/mod_jasidenews/default.php on line 20
    Left position : This error appears : Warning: Invalid argument supplied for foreach() in /htdocs/public/www/modules/mod_jasidenews/tmpl/sidenews_content.php on line 18
    (same problem with all the videos)
    I’ve check my components with Ja-ext-manager and the updates are OK
    Help me please :((
    The official opening is for the september 10th and I can’t resolve these problems
    PS : don’t use the “home / accueil ” shortcut or you will be redirect at the waiting page index.html
    jooservices Friend
    #411172
    I’m checking your issue. Please allow moment
    jooservices Friend
    #411173
    JA Comment should have some trouble with database insert. Allow me a day for checking, please.
    Another issues please update your FTP account so i can login and check / fix it
    Thank you
    Viet Vu
    franckyky Friend
    #411290
    Thank you for your help 🙂
    I sent you a FTP account in PM.
    Franck.
    jooservices Friend
    #411341
    I’ve received your PM will try to check and fix it for you in a day.
    Thank you
    Viet Vu
    franckyky Friend
    #411513
    Thank you very much.
    I will await your feedback.
    Sincerely,
    Franck
    jooservices Friend
    #411612
    Hi there,
    I’m still under checking this issue. It’s looks like our bugs.
    Please allow me a time.
    Thank you
    Viet Vu
    jooservices Friend
    #411616
    There are lots of bugs.
    I’m sorry for delayed this issue for SOLVED.
    Right now i’ve just fixed a bug ajax error because incorrect params used in JAComment Model.
    I’ll update to you everything i can find out and fix it.
    Thank you
    Viet Vu
    jooservices Friend
    #411629
    I have fixed your issue.
    #1. Because by somehow your database have missed 2 fields in table. ( Did you upgrade JA Comment from older version ? )
    #2. Another else, ya our bugs.
    Please give me access into your database for fixing.
    Thank you
    Viet Vu
    franckyky Friend
    #411760
    #1 : Yes I updated with ja-ext-manager from an old version (component 1.0.3 module 1.0.2)
    #2 : I sent you my database information in PM
    Sincerely,
    Franck
    franckyky Friend
    #412232
    Hi Viet Vu,
    Did you receive the information for my database and found some answer to your bugs ?
    Sincerely,
    Franck
    jooservices Friend
    #412283
    Let’s me check. Sorry i’ve went out of computer fews day for some works 🙂
    Thank you
    Viet Vu
    jooservices Friend
    #412285
    I’ve fixed please try at your side.
    About issue w/ JA Slidenews i don’t see it bugs anymore on your site.
    Thank you
    Viet Vu
    ps:// i’ll mention out dev team about bug when make upgrade from older version.
    Thank you
    Viet Vu
    franckyky Friend
    #412291
    JA SlideNews
    I’ve checked it : All is ok from my side. Thank you very much for that.
    JA Comment
    As said in my first message, the module in user8 position (index.php) don’t show all information. Is it a bad configuration in the back end or a bug from the module ?
    Thank’s
    jooservices Friend
    #412292
    About JA latestcomment on Myth template. I’ve checked into code ( overrided ), it look like dont have code to show comment ( although module params had this option ).
    I’ve added this code.
    But i don’t know how will it look, so … i’m going to check it dev team about this concept and reply to you in a day
    Thank you
    Viet Vu
This topic contains 19 replies, has 2 voices, and was last updated by  jooservices 13 years, 3 months ago.
