  • nvestor24 Friend
    #175679
    dear guys,
    i have installed the ja nex template for joomla 2.5. it runs like a charm. but i have some problems
    with the ja-contentslider module in the frontsite.
    first:
    i need the slider in a height of 196 px. the content-title, the image and the read more button of each item should be coloring in blue by hovering. see the attachment. the height of div in the backoffice is currently 300px. – the advantage is, the body of the items are blue by hovering. the disadvantage is – the space downstairs is to much.
    second:
    the content-titles should align: center next to the images not flushed.
    i hope somebody can help!!
    this is my first work by joomla 2.5 and the framework t3. iam a great fan of joomlart, but i cant understand, why i get problems by checking the css-codes with firebug in firefox … it calls … f.e.css_953519.css instead of template.css or layout.css ?
    can somebody explain me the situation ?
    regards
    torsten
    1. wrong
    2. right
    khoand Friend
    #446881
    You edit content slider module, you Height of Div is 196
    Because css optimize mode is ON. To turn it off, you login backend > extensions > template manager > ja_nex > set Optimize CSS is No
    nvestor24 Friend
    #446902
    hello khoand,
    thank you for the fast answering.
    this is my problem. if i turn Height of Div to 196 the result looks like this ( attachment) 😀
    i need the headline, the image and the read more info in blue color (see my second pic) if the mouse is hover!!!!!!
    thanks for the tip with the optimize css. it rocks ..
    best regards
    torsten
    1. wrong2
    khoand Friend
    #447153
    You keep Height of Div is 196, and give me a link to your website. I will check it
    nvestor24 Friend
    #450320
    this is not my problem, my problem is – that i need the show button driven in the middle of the modul !!! – and the space between the slider and the new content (modul) smaller. looks like this !
    best regards
    torsten
    1. new-try
    khoand Friend
    #450355
    Could you give me a link to your website? I will check it<em>@nvestor24 316230 wrote:</em><blockquote>this is not my problem, my problem is – that i need the show button driven in the middle of the modul !!! – and the space between the slider and the new content (modul) smaller. looks like this !
    best regards
    torsten</blockquote>
    khoand Friend
    #450543
    I saw your website, height of each items of contentslider is 240px. So I still think solution is that change Height of Div to solve your issue.
    If it’s not solution for you, you give me username+password of your backend and ftp. I will try to check it.
This topic contains 7 replies, has 2 voices, and was last updated by  khoand 12 years, 7 months ago.
