July 14, 2008 at 1:47 pm #130838
I am using template JA_Utahia II and I would like to use the JA Iconmenu in the topmenu like in yours demo.
When the icons are small they are visualized correctly while when they are large the image is wrong (see image attached).
I have copied the icons of 32×32 (name.png) and 64×64 (name-big.png) in the directory images/stories
The probles there is with IE 6 but not with Mozilla.
The same problem is also in your area demo.
What do Ido in order to see the icons correctly when they are larges?
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 17, 2008 at 10:22 am #260485Hi
Plz send your URLJuly 18, 2008 at 2:21 pm #260747Hi,
the link is http://www.levior.it/cli_004 (it’s a temporary site not completed).
I think that the problem is in something on my PC because I tried with another PC with the same version of Internet Explore (7.0.5730.13) and it’s OK!
Thanks.Sherlock FriendSherlock
July 19, 2008 at 3:03 am #260808Okie
I tested with my IE 6,7 and everything is okieAuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by Sherlock 16 years, 5 months ago.
Problem with Ja Iconmenu
