  • nunoc Friend
    #191966
    tenho o seguinte problema em o “JA K2 Search” em vez de aparecer dentro de um módulo aparece embutido no próprio template.
    Se colocar um módulo na mesma posição este vai ficar sobreposto ao K2 search.
    1. k2-seach
    Luna Garden Moderator
    #511204
    Hi, sorry I am not familiar with your native language, please reply back in English and I shall help you out.
    nunoc Friend
    #511241
    Sorry, translate the text and even noticed I copied the wrong …:)
    I have the following problem with “JA K2 Search”, after I put the “Module Class Suffix” in the module, the style appears only in the module header and the remaining fields appear embedded in the template itself.
    If you put a module in the same position this will be superimposed on the K2 search.
    I inserted a new image that exemplifies a little better my problem.
    1. k2-seach
    #511314
    Yes, I see your problem, background is not full to all module, but the header.
    You can add more style to your default CSS file like this is:
    ul.ja-k2filter{
    overflow: hidden;
    If above solution doesn’t work, PM me your site URL, admin info and FTP account, I need to check problem on your site.
    nunoc Friend
    #511635
    That worked and solved my problem. 🙂
    Thank you.
    #511776
    You’re welcome : )
This topic contains 6 replies, has 2 voices, and was last updated by  Luna Garden 11 years ago.
