July 11, 2012 at 7:40 am #178982
Dear Sir,
I’ve a problem – hope the last one prior to go online with my new website.
I followed the suggestion from some members here in the forum to disable the features “register new user” in the JA_Login module.
This is the screenshot of the webpage and looks great (Pic1)
However, once I’m logged in, it is not possible to log out (click logout is disables) and the search module change of position (Pic2).
Look here.
How is it possible to fix it?
Many many thanks for your help!
Simone
Stork11 Friend
Stork11
- March 2011
- 431 times in 393 posts
July 12, 2012 at 4:12 am #460656Hello biotecnologi,
I went to your site but it’s different from your screenshots. Did you give me wrong site URL? Please re-check and update it.
Best regards.
July 12, 2012 at 8:02 pm #460749Hi Stork,
the website url is: http://www.biotecnologi.org/Joomla15Thanks a lot!
Stork11 FriendStork11
- March 2011
July 13, 2012 at 9:14 am #460821<em>@biotecnologi 329832 wrote:</em><blockquote>Hi Stork,
the website url is: http://www.biotecnologi.org/Joomla15Thanks a lot!</blockquote>
Hello biotecnologi,You made a custom work on JA Login module, but you custom code had mistake in “log out” section. I fixed it for you in “Joomla15/templates/ja_ironis/html/mod_jalogin/default.php” file. Please check and confirm the same.
Regards.
1 user says Thank You to Stork11 for this useful post
July 13, 2012 at 4:10 pm #460859Many thanks!
Now the log out works perfectly fine.
Could you please help me also with the search module?
I inserted the search module in the top-black bar. However, once I’m logged in, the search module is shifted down and is outside the black bar.
best regards
SimoneStork11 FriendStork11
- March 2011
July 17, 2012 at 2:59 am #461093Hello biotecnologi,
Your problem with search box was resolved. Again, this issue came from your custom JA Login module file “Joomla15/templates/ja_ironis/html/mod_jalogin/default.php”.
Best regards.
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by Stork11 12 years, 4 months ago.
