  • emilioh Friend
    #981541
    Problem with JA Magz II, dont work when the article its a video
    want to remove the socials
    any idea
    Could you explain in details wich type of issue are you encountering ?
    Go to extensions -> Templates -> Your default template -> General Tab -> Show Sharing buttons -> Off
    1. Screenshot-at-ott-28-19-26-27
    emilioh Friend
    #981550
    I mean , when article is made by JA Content Type plugin (video) the JA Comment just dont work
    could you share here as private reply a temp super user account to your backend ?
    I will take a look at it
    emilioh Friend
    #983489
    Hi there
    This seems to be a problem of ja comment with video article type . i forwarded it to joomlart developers to have them looking at it , please be patient until they debug it and answer with a solution.
    Best regards.
This topic contains 5 replies, has 2 voices, and was last updated by  pavit 8 years, 1 month ago.
