Viewing 15 posts - 16 through 30 (of 35 total)
  • azri445 Friend
    #694764
    sorry…its not working with jomsocial 4.1.0 …. seem we nee to wait for the update
    azri445 Friend
    #750398
    azri445 Friend
    #694765
    its still working on jomsocial 4.0.10
    azri445 Friend
    #750399
    Pulcinella srls Friend
    #694766
    Ok, now I have need update for jomsocial 4.1, when of the update of the module?
    I need now for other two points:
    2) I don’t try the module for jomsocial login and notification bar, for now I have only name and log out without notification icons (see the screenshot)
    3) I would to see module in the positions js_side_frontpage, js_side_frontpage_bottom and js_side_frontpage_top in all the jomsocial pages (not only in the jomsocial home)
    Best
    #750400
    Best
    azri445 Friend
    #694768
    For your information, the JA Socail ll NOT compatible with Jomsocial 4.1.0 , BUT if you use Jomsocial 4.0.10 , you can re-create as the demo version. Hope that will answer your question for no 1 & 2.
    for No 3, Jomsocial template can’t be change. Yes its a bit disapointed, i also want the Jomsocial Global position NOT profile position to be stacked. I have submit the problem to Jomsocial team already. BUT haven’t get any update from them yet.
    I also want all my nodule to be loaded instead stacking 🙂 i think we just need to wait for it. Your idea same as mine 🙂
    azri445 Friend
    #750402
    #694771
    thanks a lot, you know more or less when we will be updating the template to 4.1?
    #750405
    azri445 Friend
    #694773
    Hehehhe… im still waiting for the good news too, but we just hope joomlart will update the template A.S.A.P …cross finger 🙂
    azri445 Friend
    #750407
    Adam M Moderator
    #695331
    Hi @pulcinella, @azri445:
    I raised a bug report so our development team can check and implement the fix asap, please stay tuned.
    Adam M Moderator
    #750572
    xavkick22 Friend
    #695441
    The question is :
    WHY Joomlart is selling JA SOCIAL II and JOMSOCIAL 4 and after buying they told it’s not working !! >:(
This topic contains 35 replies, has 4 voices, and was last updated by  Adam M 9 years, 2 months ago.
