  • weblogy Friend
    #726191
    Hello ,
    I try to set up a multilingual site on this website: http://afriquefemme.com/
    The template used is JA Mitius, and I use the JA Multilangual component, but the problem arises at slide during the English translation, the slide is not displayed. the module name used is JA Slideshow Lite
    PS : I make these changes locally and not online, will find attached the screenshots that show the problem
    Thank you .
    Adam M Moderator
    #754798
    Hi @weblogy,
    Please check the slideshow module setting. If you have different slideshow module for each language, make sure they’re assigned to appropriate language (menu item as well). In case you’re using 1 slideshow module for all language, make sure it’s assigned to all language.
    weblogy Friend
    #754813
    I use a different module for each language and the assignment of language is good for each module .
    Thanks .
    weblogy Friend
    #754816
    And even when I use the same module for both languages, it appears the original language of the site (French) but not for the second language (English) .
    I suspect a conflict of js files
    Adam M Moderator
    #754899
    Hi @weblogy,
    Could you please provide a temporary admin account via private reply so I can investigate the problem for you ?
This topic contains 5 replies, has 2 voices, and was last updated by  Adam M 9 years, 1 month ago.
