September 4, 2011 at 9:37 am #168157
Hi !
I use telline iv. In the JA News Frontpage Module, i can not show more than 5 articles, although i choose that option !
My web site is : http://www.petie.grCan someone help ?
Dennis
pavit Moderatorpavit
September 4, 2011 at 10:02 am #410468<em>@dion77 264988 wrote:</em><blockquote>Hi !
My web site is : http://www.petie.grCan someone help ?</blockquote>
Hi dion77
Try to disable your module cache
September 4, 2011 at 10:10 am #410469Hi !
I have done that allready !
September 4, 2011 at 10:15 am #410470Can you provide via PM an admin account to your site ?
September 4, 2011 at 11:03 am #410472Hi
I’ve checked your site
The Ja_News front page module works fine it shows only front page articles
Please check all articles and enable “front page”
See also http://www.joomlart.com/forums/topic/ja-teline-iv-userguide/
September 4, 2011 at 5:08 pm #410512the problem remains.
I can not post more that 5 articles in any profile !pavit Moderatorpavit
September 4, 2011 at 6:36 pm #410535Hi
I can’t login to your site with the credential that you have sent to me
September 4, 2011 at 6:43 pm #410537It’s because i have reset it with a backup file.
One other thing you should know is that i have reinstall news fp
isend you with PM the codesThank you
September 4, 2011 at 7:24 pm #410540Hi
as you can see now it works
Now you can customize it as your needs
September 4, 2011 at 7:28 pm #410541But noe there is one other problem.
The module of mod_janewspro underneath has big distances between the links !September 4, 2011 at 7:33 pm #410542But now there are 2 other problems :
1/. The module of mod_janewspro underneath has big distances between the links !
2/. the sl1-r modules (right) don’t work !pavit Moderatorpavit
September 4, 2011 at 7:37 pm #410544Hi
you can fix them by changing the options module, you can change the thumbnail size, or the amount of words to display in preview etc etc
look here http://www.joomlart.com/forums/topic/ja-news-front-page-module-installation-guide/
September 4, 2011 at 7:39 pm #410545and for sl1-r too ?
What was the problem ?September 4, 2011 at 7:43 pm #410547Now i can’t pablish any module in sl1-r position !
(it is right of the position in the module you fix !)September 4, 2011 at 7:49 pm #410550Now everything is perfect !
What you have done ?!AuthorPostsThis topic contains 16 replies, has 2 voices, and was last updated by pavit 13 years, 3 months ago.
