May 17, 2007 at 2:02 pm #120290
I have installed JA-NewsFlash but it gives the following errors when the page loads.
Hope you can help
MurrayErrors
Notice: Undefined variable: items in /home/offroad2/joom/modules/ja_newsflash/ja-newsflashloader.php on line 263Notice: Undefined variable: firstnew in /home/offroad2/joom/modules/ja_newsflash/ja-newsflashloader.php on line 280
Notice: Trying to get property of non-object in /home/offroad2/joom/modules/ja_newsflash/ja-newsflashloader.php on line 280
Notice: Undefined variable: splitter in /home/offroad2/joom/modules/ja_newsflash/ja-newsflashloader.php on line 285
Notice: Undefined property: stdClass::$Itemid_link in /home/offroad2/joom/modules/ja_newsflash/ja-newsflashloader.php on line 206
ShannonN FriendShannonN
- July 2006
- 172 times in 49 posts
May 18, 2007 at 12:58 pm #220268yarrum;15668Hi
Hope you can help
MurrayErrors
I’d suggest you uninstall and then reinstall it and see if that solves it? if not then post back and we;ll try other options, Dl the latest version from teh site also in case thee has been any updates
Cheers ShannonN
May 18, 2007 at 3:24 pm #220284i get the sama problem.
Please help
- July 2006
May 18, 2007 at 11:24 pm #220312imaginante;15778i get the sama problem.
Please help
same problem? try same solution
Cheers ShannonN
May 21, 2007 at 4:04 am #220515Hi Shannon
I have unistalled the module,
download it again from ja and installed
…. but I get the same errors as above.Regards
MurrayJuly 2, 2007 at 4:21 am #223138I wish someone would respond so we can get it fixed. Would be great for my site if it would work correctly.
- July 2006
July 2, 2007 at 7:42 am #223146lisas;19582I wish someone would respond so we can get it fixed. Would be great for my site if it would work correctly.
what have you done to solve it ? lisas?
instead of wishing someone would solve it, helps us by posting a live url so we can look at the site in actionIf you want the site to work correctly you have to know what your doing and try a few things yourself we can’t wave wands and get it happening
qbali JATCqbali
- October 2006
- 2 times in 1 posts
July 3, 2007 at 2:09 am #223227who is in actually responsibility to give us the solution for our problem ?
- July 2006
July 3, 2007 at 2:54 am #223236qbali;19692who is in actually responsibility to give us the solution for our problem ?
What actually is your particular problem with Ja newsflash?
To answer your actual question on support responsibility . . . .In theory as it is a JA extension the JA developer who is responsible for making it has the responsibility to answer technical questions about it, but he doesn’t seem to be available so any of the community that feels they can help, or support the poster usually tries their best to answer questions etc
You can of course understand that while many here use the extension successfully they may not have the technical ability to answer some questions
July 3, 2007 at 3:09 am #223238<blockquote> Problem with JA-NewsFlash
HiI have installed JA-NewsFlash but it gives the following errors when the page loads.
Hope you can help
MurrayErrors
Notice: Undefined property: stdClass::$Itemid_link in /home/offroad2/joom/modules/ja_newsflash/ja-newsflashloader.php on line 206</blockquote>
It seems most of the problem lies in this little section:
If you use a text editor like TextPad you can view the file and actually go and look at what that line of code says. .
// check if any results returned
if ( $numrows ) {
$curnews = intval( mosGetParam( $_REQUEST, 'curnews' ) );srand ((double) microtime() * 1000000);
while (true) {
$flashnum = rand( 0, $numrows-1 );
if ($flashnum != $curnews) break;
$row = $rows[$flashnum];
}$Itemid = $mainframe->getItemid( $firstnew->id, 0, 0, 1, 1, 1 );
$row->introtext = textprocess($row->introtext);
$row->fulltext = textprocess($row->fulltext);if(!$splitter) {
echo "<div id="ja-newsflash">";
ja_output_newsflash( $row, $params, $access );
echo "</div>";
} else {
echo $splitter.$flashnum;
Could be a permissions problem .. .
Do you have ANY published content? It seems that it might be creating a Page Preview but cannot find either the ItemID of the content or it doesn;t have the rights to create it???
Who is your hosting provider? Is it a new site? Old site w/ new template setup? Have you checked your permissions? What is the URL of the site so we can test. Is this the ONLY module you are having trouble with? Have you checked your error logs? Web Server Error Logs?
July 28, 2007 at 6:22 am #225359<em>@ncrc 19703 wrote:</em><blockquote>It seems most of the problem lies in this little section:
if ( $numrows ) {
while (true) {
echo "</div>";
} else {
Who is your hosting provider? Is it a new site? Old site w/ new template setup? Have you checked your permissions? What is the URL of the site so we can test. Is this the ONLY module you are having trouble with? Have you checked your error logs? Web Server Error Logs?</blockquote>
i have the same problem…but couldnt find the solution for it. have you solved?qbali JATCqbali
- October 2006
July 30, 2007 at 2:26 am #225563as my experienced to this rochea, i just uninstall the simple image gallery and the newsflash will work well, if you have simple image gallery the newsflash will never work,
i don,t know why. but this tricks works for mehope this help
August 3, 2007 at 10:48 am #226222<em>@qbali 22605 wrote:</em><blockquote>as my experienced to this rochea, i just uninstall the simple image gallery and the newsflash will work well, if you have simple image gallery the newsflash will never work,
i don,t know why. but this tricks works for mehope this help</blockquote>
Not true; I have Simple Image Gallery PRO (not sure if there is a difference because I am using PRO) and newsflash does not output any errors.swemmel Friendswemmel
- February 2006
- 64 times in 1 posts
August 3, 2007 at 10:55 am #226223mwbarker;23365Not true; I have Simple Image Gallery PRO (not sure if there is a difference because I am using PRO) and newsflash does not output any errors.
In SIG Pro you can choose between different popup-engines, in SIG free not. Maybe that is the difference. Maybe the popup-engine of SIG free is not compatible with the jscript that is used with newsflash.
Peter.
This topic contains 14 replies, has 9 voices, and was last updated by swemmel 17 years, 5 months ago.
