  • majdi2 Friend
    #148251
    The JA Newsflash is displaying items at random, but it keeps on repeating some items before proceeding to the next item. How can we change this to display items in order in a loop.
    Also, is there an updated version for this extension? We are currently using JA newsflash 1.0.0. on Joomla 1.5.14.
    Thanks.
    majdi2 Friend
    #331307
    Can anyone help with this?
    Anonymous Moderator
    #331388
    Hi majdi2
    i am sorry for this later.
    In administrator, you can go to administrator, edit ja news flash, select Articles Sort Order By to your idea
    If you could not find this option, maybe you are installing an old version of ja newsflash. You can download and install it again
    majdi2 Friend
    #331483
    Thank you for your reply. I tried searching for the latest version of JA Newsflash but could not find a download link for it. Can you please point me in the right direction. I am currently using version 1.0
    Anonymous Moderator
    #331643
    Hi there,
    Follow the link: http://www.joomlart.com/forums/downloads.php?do=file&id=723 to download JA Drimia with JA Newslide built-in.
    majdi2 Friend
    #331871
    Thanks,
    So I would not have a problem replacing JA Newsflash with JA Newslide, I mean there will be no need to code for this change?
    Anonymous Moderator
    #332006
    Hi majdi2
    I am sorry for my mistake. You can download ja raise package, extract and find this module in module folder
    majdi2 Friend
    #332032
    Did you mean the JA Rasite site, this is using the JA Slideshow and not JA Newsflash
    majdi2 Friend
    #332092
    Cant find another version for JA Newsflash. Can you please just point me to the code I will need to change to fix this.
    Thanks.
    Anonymous Moderator
    #332142
    Hi majdi2
    We don’t increase the number of version. We only update files to this package. You can download and update files again
    Hope it helps
This topic contains 10 replies, has 2 voices, and was last updated by Anonymous 14 years, 11 months ago.
