  • andreev Friend
    #185248
    Hello, I have a problem with JA Popup plug-in and iframe.
    The site is:
    http://www.inbg.bg/
    when i try to open link Iframe don’t happen. See it here:
    1. Capture
    andreev Friend
    #484331
    Wneh i put a text between {japopup type=”iframe”…} and {/japopup} it’s working.
    But when i put a image <img …/> nothing hapen. Why?
    HeR0 Friend
    #484428
    Hi Andreev,
    Please clean all cache and go to Popup plugin and set up use Fancybox.
    If the issue persist, pm me admin account, i need to closer to check then i will try to help you out.
    andreev Friend
    #484921
    Hi HeR0,
    Thaks for the answer.
    I did it, but, Popup plugin use Fancybox.
    When I change the Popup type on GreyBox, it’s work, but I WANT TO USE Fancybox type.
    Can you help me?
    HeR0 Friend
    #484982
    Hi Andreev,
    PM me admin account, ftp info,… because i need to closer look to check then i will try to help you out if possible
This topic contains 5 replies, has 2 voices, and was last updated by  HeR0 11 years, 9 months ago.
