Ninja Lead Moderator
Ninja Lead
- November 2014
- 3854 times in 3563 posts
April 20, 2015 at 7:51 am #732693<em>@insofticursos 469167 wrote:</em><blockquote>@Ninja Lead – The two problems are not resolved. I’m using Google Chrome.
Visit the beginning page, and then the link I spent in access.</blockquote>I fixed the problem on JA Promo Bar module directly on your site.
About Modelo Barra de eneder?o TOP module (with acm-header position) if you assign the module under acm-header position, you will see the logo and menu bar was hidden in this case, see the screenshot
Tech-xml FriendTech-xml
- October 2010
- 5 times in 2 posts
April 21, 2015 at 1:23 am #567685Solved, thank you
- October 2010
November 27, 2015 at 3:26 am #758677@ninja Lead The problem of bar override the mainmenu back. Can you help me?
Link: http://bit.ly/1juuWCP
- November 2014
November 27, 2015 at 5:18 am #758686You can the custom in JA Promo Bar module to fix the problem on your site
Open the modules/mod_japromobar/tmpl/default.php file
find and change
function jaClosePromoBar(){
var h = parseInt($('#ja-promo-bar-<?php echo $module->id?>').outerHeight());
$('#ja-promo-bar-<?php echo $module->id?> .inner').animate({'top':'-'+h+'px'}, '<?php echo $speed; ?>', '<?php echo $easingClose; ?>');
$('#ja-promo-bar-<?php echo $module->id?> .inner').hide('<?php echo $speed; ?>');
$('#ja-promo-bar-<?php echo $module->id?> .icon-toogle').removeClass('opened').addClass('closed');
jaPromoBarT3Nav('closed');
jaPromoBarBody('closed');
setCookie('ja_promo_bar_<?php echo $module->id?>','closed',1);
}function jaOpenPromoBar(){
$('#ja-promo-bar-<?php echo $module->id?> .inner').css('display', 'block');
$('#ja-promo-bar-<?php echo $module->id?> .inner').show('<?php echo $speed; ?>', function() {
$('#ja-promo-bar-<?php echo $module->id?> .inner').animate({'top':0}, '<?php echo $speed; ?>', '<?php echo $easingClose; ?>');
$('#ja-promo-bar-<?php echo $module->id?> .icon-toogle').removeClass('closed').addClass('opened');
jaPromoBarT3Nav('opened');
jaPromoBarBody('opened');
setCookie('ja_promo_bar_<?php echo $module->id?>','opened',1);
}to
$('.t3-header.affix').css('top','0px');
$('.t3-header.affix').css('top','59px');
Hope it helps
This topic contains 20 replies, has 2 voices, and was last updated by Tech-xml 9 years, 1 month ago.
