  • mckormick Friend
    #140345
    Hi – the quickstart fails for me when I get to the ‘Install Sample Data’ button which gives me an error
    ‘Invalid XML response from Server’.
    If I click next anyway I get an error:
    Notice: Undefined index: DBtype in /httpdocs/installation/installer/models/model.php on line 764
    No database selected
    I’ve tried on 2 separate machines – other quickstarts work fine.
    Arvind Chauhan Moderator
    #301696
    It looks more of Joomla problem :
    fixed it but I’m not sure which of the below steps fixed it-
    1. I reuploaded the /installation/ folder
    2. I did not turn on the FTP layer during install
    3. I had previously renamed the configuration-dist.php file to configuration.php and set it to ‘666’. This time I left it as is and let the install script generate the config script for me to manually add.
    This is the quote from official Joomla.org forum:
    read the full entry at :
    http://forum.joomla.org/viewtopic.php?f=429&t=201256
    Also check : http://forum.joomla.org/viewtopic.php?f=429&t=297075&p=1321585#p1321585
    Let us know>> if this is resolved.
This topic contains 2 replies, has 2 voices, and was last updated by  Arvind Chauhan 15 years, 8 months ago.
