  • bwgroup Friend
    #704840
    Hi!
    I am having problem with JA S3 component inside a Docker container with LAMP stack.
    Account Manager and Bucket Manager seems to be working fine. I see this message when I am on File Manager step:
    Notice: Undefined property: jaAmazonS3ViewRepolist::$cnt in /var/www/html/administrator/components/com_jaamazons3/views/repolist/tmpl/details_up.php on line 4
    Also, the Sync profile doesn’t work… I think its related to the problem above. But, not sure what it means…
    Thanks!
    – john
    Mo0nlight Moderator
    #704999
    Hello John,
    The current version of JA Amazon S3 doesn’t support Frankfurt bucket that using Signature Version 4.
    If you must use this bucket, you can send me screenshot or capture video of how to replicate the issue so that I can check and help you out.
    BigHug Friend
    #751637
    Hello John,
    bwgroup Friend
    #705182
    I am not using Frankfurt bucket that using Signature Version 4…
    Attached please find the screenshot with the error message.
    Thanks!
    bwgroup Friend
    #751733
    Thanks!
    Mo0nlight Moderator
    #705253
    Hello John,
    Actually, it’s just a warning message and will not affect function on your site. To get rid of this message, you can go to Global Configuration > Server tab and set ‘Error Reporting’ to No.
    This notice message may due to the local server that your site is running with, you can put your site online and if it still occurs, PM me the access info, I will check further for you.
    Mo0nlight Moderator
    #751789
    Hello John,
This topic contains 7 replies, has 3 voices, and was last updated by  Mo0nlight 9 years, 2 months ago.
