  • fulldesign Friend
    #175489
    Hello, I have a problem.. I don’t understand why, when I click on the three box on the home page, the link dont’t redirect me at the article… Someone have a solution?
    Andrea
    1. Schermata-2012-03-28-a-08.38.56
    Salve Andrea
    Potresti inviarmi un account da admin via PM in modo da poter controllare la tua configurazione ?
    Grazie
    alewebg Friend
    #473477
    I am having the same problem.
    I wait for your reply here. Thanks
    <em>@alewebg 346945 wrote:</em><blockquote>I am having the same problem.
    I wait for your reply here. Thanks</blockquote>
    Could you post a link to your site and PM me your admin access details ?
    alewebg Friend
    #480000
    <em>@pavit 346946 wrote:</em><blockquote>Could you post a link to your site and PM me your admin access details ?</blockquote>
    I solved Pavit, thanks. It was just a smiple mistake of mine
    nexusict Friend
    #482359
    <em>@alewebg 355482 wrote:</em><blockquote>I solved Pavit, thanks. It was just a smiple mistake of mine</blockquote>
    What is the solution?
    Hi nexusict
    Could you send me via PM your admin details credentials ? i will check your actual configuration and reply to you with the solution here
    Ninja Lead Moderator
    #482505
    <em>@nexusict 358642 wrote:</em><blockquote>What is the solution?</blockquote>
    I asked @pavit but he doesn’t remember the solution to fixed it
    If possible send me the screenshot, url on your site. I shall check it and help you out.
    brentsr Friend
    #497055
    This thread has the solution: http://www.joomlart.com/forums/topic/ja-side-news-more-info-links-broken/
    Basically, you need to create a new, invisible menu and link it to the articles and the Side News Module. I was having the same problem, and it solved my issue.
    pradeep_rs Friend
    #505941
    What was the solution?
    Could you send me via PM a super user account for your backend i will try to take a look and solve this problem for you
This topic contains 11 replies, has 7 voices, and was last updated by  pavit 11 years, 3 months ago.
