  • Manos Krokos Friend
    #195514
    Hello, all of a sudden my site’s homepage stopped showing the K2 feat. It produces the following error.
    Warning: Invalid argument supplied for foreach() in /home/edraedug/public_html/templates/ja_university/html/mod_jasidenews/default.php on line 17
    Nothing has been changed to my knowledge.
    Kind regards,
    Manos K
    chavan Friend
    #525544
    I have simple and a temporary solution.
    Go to Administrator -> site -> Configuration -> server tab -> set error reporting to “none”
    this will fix the warning show up
    Manos Krokos Friend
    #525553
    <em>@Chavan 414914 wrote:</em><blockquote>I have simple and a temporary solution.
    this will fix the warning show up</blockquote>
    Thanks but this won’t solve the issue of the K2 featured items not showing at all
    chavan Friend
    #525556
    please explain the issue in precise.
    as per your post you need to get rid of that warning message. so I suggested to disable error reporting.
    Please advice
    Manos Krokos Friend
    #525560
    Please, have a look at the homepage of my site: http://www.edra.edu.gr
    As you can see, the JA Sidenews module is totally empty. It was working until yesterday, pulling the featured items from all K2 categories. As suggested, I disabled the error reporting but that didn’t bring back the content.
    I am enable the reporting again, so you can see where the content should appear.
    chavan Friend
    #525591
    There is a htaccess prevents me to go into your http://www.edra.edu.gr/administrator/
    so please either remove that or give me the password to enter into your admin
    Manos Krokos Friend
    #525611
    Thanks for the effort. This is a plain human check. Use these credentials:
    U: human
    P: password
    chavan Friend
    #525625
    Other than the category, you have no items in your K2 components. That is the reason you are seeing a empty result
    Manos Krokos Friend
    #525629
    Hello, and thanks for the help. It never crossed my mind to check the K2 items. Of course, there were still in the database but the table was crashed and needed repair. Now, it’s OK.
    Thanks again!
This topic contains 9 replies, has 2 voices, and was last updated by  Manos Krokos 10 years, 9 months ago.
