March 18, 2012 at 2:42 am #175122
Hello everyone, i have a small issue with this module, the thing is that I installed this module and put it in left-mass-top position, with only two articles, in a category named “Info”. I added a new button to the menu with this articles too, to show them as a category blog.
When i’m on the frontpage, if I click on the read more link, it shows me the article in the frontpage, with all the other modules, instead of asociating with the menu item, a clean page.
Is there any way to fix this?
I’m working on localhost, but if it’s really needed I think I can upload it.
I checked if this problem was solved, someone had this problem but no solution was foundThank you very much!
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
March 18, 2012 at 3:33 am #444260Hello,
This is really weird it should be fine if you have a menu item associated with it, i know that many people usually don’t use SEF URL’s on localhost but check just in case you have the SEF option enabled and try again.
If this doesn’t solve your problem i will need to see the website so i can try and help you.
March 18, 2012 at 3:41 am #444261hi Pascm, thanks for the quick reply
I disabled it earlier today because it was giving me those kind of errors, and it fixed them, but now didn’t
I’ll update the post when I upload the site, and send you the access info by PM
Thank you again!
- February 2014
March 18, 2012 at 3:37 pm #444340Anytime! I am always here to help 🙂
March 22, 2012 at 2:16 pm #445100hi Pascm, i’ve sent you a PM! 🙂
- February 2014
March 22, 2012 at 8:01 pm #445165Hi,
I received your PM and visited your website but i couldn’t reproduce the problem, both articles that are shown in JA Slideshow module open in a new page isn’t that what you wanted ?
March 24, 2012 at 11:39 pm #445494<em>@pascm 309439 wrote:</em><blockquote>Hi,
Regards</blockquote>
Yes!.. I guess that when I uploaded it, it started working well, because in localhost i had that problem, In fact I didn’t check if it was working when I uploaded it, what an ass… haha thank you very much! If any other has this problem don’t worry, it will work fine when the site is online
Best wishes and thank you for your time!
This topic contains 8 replies, has 2 voices, and was last updated by Manos 12 years, 9 months ago.
