  • simone82 Friend
    #183970
    Hi guys,
    recently I purchased a plugin for OG properties control. It conflict with JA Social plugin that generated some code, perhaps wrong.
    I need to use the fb-like option, but without the meta properties automatically generated under tag “head”.
    As I write, the code it seem wrong, because the og:site_name took content from description and not from Joomla site name global configuration.
    I try to delete this lines from sucbuttons.php:
    $document->addCustomTag('<meta property="og:site_name" content="'.$config->getValue('sitename').'"/>');
    $document->addCustomTag('<meta property="og:title" content="'.$row->title.'"/>');
    $document->addCustomTag('<meta property="og:type" content="article"/>');
    $document->addCustomTag('<meta property="og:url" content="'.$link.'"/>');
    but the code persist on page… Can you help me? :((
    I’m on JA Mero template at http://www.simonegianolio.info
    simone82 Friend
    #479652
    Please note that I confuse the JA Social plugin with SocButtons plugin… :-[
    The wrong code persist, but I delete the following lines in jasocial.php to resolve my problem:
    $tags .= '<meta property="og:title" content="' . $titleshare . '"/>' . "rn";
    $tags .= '<meta property="og:site_name" content="' . $document->getDescription() . '"/>' . "rn";
    if($imageshare){
    $tags .= '<meta property="og:image" content="' . $imageshare . '"/>';
    if(!empty($descriptionshare)){
    $tags .= '<meta name="og:description" content="'.$descriptionshare.'" />';
    $tags .= '<meta name="og:url" content="'.$this->curPageURL().'" />';
    if(!empty($app_id)) {
    $tags .= '<meta property="og:app_id" content="' . $app_id . '" />';
    $body = $this->str_ireplace('<head>', '<head>' . "rn" . $tags, $body, 1);
    Have you another suggestion?
    Stork11 Friend
    #479787
    Hello simone82,
    You can use below code to get your site name
    [PHP]
    $config = JFactory::getConfig();
    $_siteName = $config->getValue( ‘config.sitename’ );
    [/PHP]
    After that, use $_siteName instead $document->getDescription()
    Hope this helps.
    Regards.
This topic contains 3 replies, has 2 voices, and was last updated by  Stork11 11 years, 11 months ago.
