  • myilance Friend
    #159264
    Please help me !
    I have JA Events template and Joom Bah component .
    When i try to change The Country, State needs to load automatic with mootools 1.2 (see the picture) The problem is in T3 System plugin. Can you change the plugin to load mootools 1.2 ?
    Please see the 2 files . One is with JA T3 System plugin the other is with JA_Purity template without T3 System plugin.
    Please give me solution because my website is running all ready
    Thank you
    1. Untitled
    2. 3
    Yes, mate
    Please copy the component.php from the template/ja_purity folder and then replace this file in the template/ja_rave/ folder
    to resolve the issue
    thanks
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 13 years, 11 months ago.
