Viewing 15 posts - 1 through 15 (of 46 total)
  • jmccann Friend
    #131090
    HI,
    I have installed JA TABs but when I go into Module I get the following error:
    JFolder::folder: Path is not a folder /mysitepath/plugins/content/ja_tabs/themes/
    Can I just create a directory, or do I need any content?
    #261043
    Hi jmccann !
    Have you installed plugin JA Tabs ? You must install Plugin JA Tabs if want use JA Tabs module.
    that4345 Friend
    #422425
    <em>@hainn84 68095 wrote:</em><blockquote>Hi jmccann !
    Have you installed plugin JA Tabs ? You must install Plugin JA Tabs if want use JA Tabs module.</blockquote>
    Thank you very much !!!
    itzwiki Friend
    #441965
    Dear Joomla Developers,
    I Have an issue for 2 weeks. and i m fed off now. joomla plugins and modules are making my hairs off. plzzzz plzzz help me out of here.
    Issue:
    I Configure
    PHP, My sql and Joomla on IIS 7.0
    BY Akeeba Backup, I run it on my IIS 7.0.
    Everything Works Fine. But JA TABS are not working, showing Code.
    JA TABS contains modules with Background image and Shadow effects modules (in my admin panel i see)
    When i paste the code in Article. it works Good and show Tabs. but in modules, it shows CODE on the PAGE and effects works fine.
    Please help me out……….!!!
    Phill Moderator
    #441984
    Please give us a link to your site so we can see the problem.
    itzwiki Friend
    #442008
    First of all, thnx for the notice 🙂
    Here is the link on my server:
    http://209.80.43.77/services/wastewater
    and
    here is the link to the orignal site.
    http://www.eecworld.com/services/wastewater
    You can compare JA TABS at the bottom of the pages.
    Plzzzz help me out !!
    Phill Moderator
    #442010
    It appears you do not have the plugin installed. To get the plugin you need to be a member but your login appears to be that of a free member, not the paid one required to use the JA Tabs plugin.
    itzwiki Friend
    #442147
    i also have paid membership.
    JA Tabs are installed and i tested it on a new page with code inside the article. it works fine in the article.
    But not in Module. module of mod_jatabs are created and it generates auto code that is shown on the page. i copied that code and place directly in the article and it works…
    Module is a problem for me..
    i can show you if u want to see the JA TABS in Article section.
    Phill Moderator
    #442149
    Can you logon to the forums with the account that you have paid membership with because the account you are using does not appear to do so.
    watchstevedrum Friend
    #442154
    itzwiki >
    I dont know why u want me to login with this account, as it has no concern with it.
    So, here i am. now plz tell me what should i do now ?
    Phill Moderator
    #442158
    You have to understand that we cannot provide support to members that do not appear to have paid for products they are using. itswiki is one such user. The visibility is that of a free member so we cannot provide support on a paid product. I shall move this thread to the relavent section.
    Phill Moderator
    #442159
    watchstevedrum,
    Could you plead PM me a super admin logon and a link to your site so I can take a look for you.
    #442160
    Oooh…..!!! So, that was the reason. thats gud but it has cons instead of pros.
    Well, u have the POlicies to follow. no one bother it.
    Now where should i go and ask the Q ? :((
    Phill Moderator
    #442161
    As per above, drop me a PM with a super admin logon and a link to your site so we can take a look and fix this for you.
    #442162
This topic contains 46 replies, has 6 voices, and was last updated by  watchstevedrum 12 years, 9 months ago.
