  • antonio forte Friend
    #154916
    I have installed Portfolio to another web site with a recent php version and there is not problem. I have installed ja tabs plugin and module, I have chosen content-mass-top as position, and the correct number of categories with the correct option…..
    But the modulo don’t show anything ! :((
    scotty Friend
    #357650
    Please don’t title threads with generic titles like ‘Another problem’.
    Do you have a live URL we can look at to see if anything is being rendered by the module? Have you turned on error reporting to see if there are any PHP errors being produced?
    smitheringale Friend
    #357672
    <em>@cyber81 196786 wrote:</em><blockquote>I have installed Portfolio to another web site with a recent php version and there is not problem. I have installed ja tabs plugin and module, I have chosen content-mass-top as position, and the correct number of categories with the correct option…..
    But the modulo don’t show anything ! :((</blockquote>
    JA Tabs is an interesting one.
    To the best of my knowledge….
    You need to make sure the Ja Tabs module is published in the correct position AND that the modules controlled by Ja Tabs are in the correct position.
    For example, publishing the modules to be controlled by Ja Tabs in the content-mass-top position won’t work. They will need to be published in tabs position (for example), where tabs (or whatever) as specified in the ja-tabs module that has of course been published to content-mass-top.
    #357680
    Hello, thanks fot the answers, ja_tab now is on. But I installed it another time, then the plugin.. I must learn much more on ja_tabs…but for the moment is on.. 🙂
    watchstevedrum Friend
    #442361
    Dear Joomla Developers,
    I Have an issue for 2 weeks. and i m fed off now. joomla plugins and modules are making my hairs off. plzzzz plzzz help me out of here.
    Issue:
    I Configure
    PHP, My sql and Joomla on IIS 7.0
    BY Akeeba Backup, I run it on my IIS 7.0.
    Everything Works Fine. But JA TABS are not working, showing Code.
    JA TABS contains modules with Background image and Shadow effects modules (in my admin panel i see)
    When i paste the code in Article. it works Good and show Tabs. but in modules, it shows CODE on the PAGE and effects works fine.
    Please help me out……….!!!
This topic contains 5 replies, has 4 voices, and was last updated by  watchstevedrum 12 years, 9 months ago.
