  • kenkel22 Friend
    #135736
    I have setup ja tabs on my home page – example attached. Usually when I login I get the example first and then I refresh and the JA Tabs appear only then. Any ideas?
    1. badscreen
    #280473
    Hi kenkel22 !
    You need must assign some module to user6 position for tabs display, if posible, please send url of your site and admin account via pm , i will check it for you !
    kenkel22 Friend
    #281012
    did you get my pm? the tabs do not appear when i open the page the first time but then if I go to a different page and come back , the tabs then appear fairly consistently.
    sunrise Friend
    #281016
    Does it do the same in every browser, or is it a browser related problem?
    #281053
    No kenkel22 , i have check teline ii quickstart with IE6, IE7, firefox and can’t see the problem , if you please send url of your site, it seems can’t load css for tabs on first time.
    kenkel22 Friend
    #281099
    ok i just resent my pm to you at hainn84. let me know if you got it. you can delete this post if you want – i don’t know how else to be sure I get to you.
    #281207
    Hi kenkel22 !
    Please click on “Philanthropy at AWS ” menu and check , ja tabs displays now , I have checked and detect the problem , Only have one “user6” module is assign for display on “Philanthropy at AWS ” page. so tabs can’t display, you must make sure that at lease there are 2 user6 module are assign for display on a page.
    kenkel22 Friend
    #281267
    yes i am aware of that but the home page will not display on the initial entry to the home page. Only after you refresh the browser does it then appear. you have to login with the details I sent to you to get the home page to display.
    #281340
    Hi kenkel22 !
    Please login and check again ! it is ok now , i Have re-assigned for General News module for it display of Home menu item of all menu. and it is ok now.
    kenkel22 Friend
    #281611
    you are the BEST! thank you so much for taking the time to help me resolve this issue! It looks great !
This topic contains 10 replies, has 3 voices, and was last updated by  kenkel22 16 years ago.
