  • deep81 Friend
    #195658
    I have problem with JA Tabs. It works normaly except on ipad2. On ipad, it looks that it do not load some scripts, the tabs do not work and products from both tabs are split together. I think it is not problem with my site, because ja tabs do not work on your demosite too (http://ja-bookshop.demo.joomlart.com).
    You may test it on ipad simulator here: http://transmog.net/iphone-simulator/mobile-web-browser-emulator-for-ipad-2.php
    Nazario A Friend
    #526444
    @deep81,
    On the horizontal of iPad, JA Tabs is working fine.
    But on the vertical of iPad, JA Tabs will be hidden.
    Please try to check again. If the problem still persists, you can post the screenshot highlighting your problem here and PM me the URL, Admin credential so that I can help you out.
    1. bookshop4
    2. bookshop5
This topic contains 2 replies, has 2 voices, and was last updated by  Nazario A 10 years, 10 months ago.
