  • adnanpirota Friend
    #167325
    I have problem with JA Thumbnail, in Category Blog pages in my webpage http://www.cyberspace-ks.com, actually thumbnail is not working (my pictures are as large as when inserted in the article).
    Trimud Friend
    #405914
    I see no thumbnail problem with Your site.
    Please see the attached screenshot.
    Also – what browser are You using and is this problem in every browser You try?
    Best Regards
    1. screenshot
    adnanpirota Friend
    #405922
    On the front page it is OK but if you enter any category inside you will see that pictures are big … thank you for prompt reply
    <em>@Trimud 259309 wrote:</em><blockquote>Hi,
    Best Regards</blockquote>
    Manos Moderator
    #405924
    Hi, can you provide with some admin user for backend access so we can take a look at your issue ?
    Best Regards
    Manos
    Manos Moderator
    #405928
    Hi, password not working can you please update?
    jooservices Friend
    #405955
    <em>@pascm 259326 wrote:</em><blockquote>Hi, password not working can you please update?</blockquote>
    Hi there,
    I’ve checked and it’s bug.
    I’ll pass this issue to dev team for check and fixing. Will update news with you 🙂
    Thank you
    Viet Vu
    adnanpirota Friend
    #405959
    <em>@jooservices 259362 wrote:</em><blockquote>Hi there,
    Thank you
    Viet Vu</blockquote>
    It is good idea to tell them to check text wrapping, because with joomla 1.5 I had similar issue i.e. pictures don’t wrap to left or right but instead they are positioned under the intro text …
    WPStrong Friend
    #406816
    Hi Adnanpirota,
    Could you PM the access to your backend panel ? I have to check some settings in the K2 component .
    Thank you,
    Le Trong.
This topic contains 8 replies, has 5 voices, and was last updated by  WPStrong 13 years, 4 months ago.
