  • englishcapricorn Friend
    #178888
    Hi there,
    Any help much appreciated… And thank you for any help given.
    I have recently bought the JA WALL Template and had it installed here: http://www.rigapropertyguide.com Using Joomla 2.5.6
    I am a newbie, and try my best with Joomla, but sometimes it’s very testing for me. Here is my problem/situation:
    Go to my w/site and the home page shows ok.
    (1.) Click “Latvia” (Or any other link) in the left hand menu. All works well. Now change to any “style” in the top menu, and the page directs to the home page. What is wrong here?
    (2.) Now click “Latvia” again, (Or any other link) and all pages are empty. What is wrong here?
    Now close browser, then re-open, test again and the sequence is the same? Tested on Firefox and Chrome. Also tested on Dolphin and Chrome in Ice cream Sandwich on HTC Sensation.
    Can anyone tell me what I might have done wrong to create this problem and how to rectify the problem? Or is my site buggy?
    Any help is much appreciated…
    Geoff,
    Stork11 Friend
    #460331
    Hello englishcapricorn,
    Your user “Tomkins” has language value “en-GB”. I changed it to “all language” in “Contact details” of “Contact” component. Then the problem was resolved. Please check and confirm the same.
    Best regards.
    #462207
    Sorry for not getting back to you sooner Sir, as I did not know you responded? Thank you for the work you done. 🙂
    However:
    Since that time I have hired three separate Designers, Joomla Experts? to work on my site, however, it seems none can do the work I asked and seemed to cause more problems than I started with.
    Thank you for fixing the initial problem. 🙂 I will post the new problem/s in another post.
    Thank you…
This topic contains 3 replies, has 2 voices, and was last updated by  englishcapricorn 12 years, 5 months ago.
The forum ‘Other Templates’ is closed to new topics and replies.
