Viewing 1 post (of 1 total)
  • srangi Friend
    #128283
    While working with the section/categories, I follow the instruction in the user manual to update the menu up top, but inevitably it does not work.
    I then tried changing the names directly from the menu manager, which then split the content into a new main menu item for any edit I made.
    Is there a way I can fix this?
    I have jreviews installed on my site, which caused the site to go down. I modified the code as follows:
    As a temporary fix, I decided to tinker around with base.class.php even though I have no clue about how coding for Joomla templates work, and I did this:
    function loadMenu(){
    if(defined(”)) $this->loadMenu_15();
    else $this->loadMenu_10x();
    function createParameterObject($param, $path=”, $type=’menu’) {
    return new mosParameters($param, $path, $type);
    Any insight into this problem would be very appreciated!
This topic contains 1 reply, has 1 voice, and was last updated by  srangi 16 years, 8 months ago.
