  • masoudgh Friend
    #190624
    hi
    i have problem with my site
    sahandkh.ir
    it seem had problem with modulehelper.php
    i’m using joomla 1.5
    and ja3 updated to 1.3
    Warning: Creating default object from empty value in /home/masoudgh/public_html/sahandkh.ir/plugins/system/jat3/core/joomla/modulehelper.php on line 320
    phong nam Friend
    #506056
    HI masoudgh,
    As you know Joomla 1.5 is no longer supported by both Joomla developers and us, JoomlArt. So that, in this case, I suggest you to backup your files and roll back to older JAT3v2 verions fro J1.5 at http://www.joomlart.com/forums/downloads.php?do=file&id=1421
    masoudgh Friend
    #506338
    <em>@Leo Burnetts 389870 wrote:</em><blockquote>HI masoudgh,
    As you know Joomla 1.5 is no longer supported by both Joomla developers and us, JoomlArt. So that, in this case, I suggest you to backup your files and roll back to older JAT3v2 verions fro J1.5 at http://www.joomlart.com/forums/downloads.php?do=file&id=1421</blockquote>
    hi dear leo
    as far as I know , i use jat3 version 1.3.3 which are the last version for joomla 1.5 and also other version for joomla 1.5
    but i’m completely confused
    there is no problem for migrating to joomla 2.5 but my template design for joomla 1.5 !!:((
    phong nam Friend
    #506361
    Hi masoudgh,
    As you know, each generation of our JAT3 system plugin is built compatibly with the Joomla version which the template runs on. So that, if you are using the Joomla 2.5, you will need to update to our JAT3v2 plugin for Joomla 2.5. In addition, you also need to backup your modified template and update with the latest version of that template.
    The reason you need to update the current to J2.5 version since the parameters of template structures are quitely different between the J1.5 and J2.5.
    Remember to clear cache after finishing to update.
This topic contains 4 replies, has 2 voices, and was last updated by  phong nam 11 years, 4 months ago.
