  • whamprod Friend
    #132398
    I just uploaded v. 1.4 for 1.5, and the system admin panel, version 1.5.6, would not install the package. So, I opened the Quickstart package, and uploaded the template files via FTP.
    When I turned on the mod_ja_header module, it started displaying the following php errors in the header:
    Warning: opendir(/home/user/wwwroot/domainname.com/templates/ja_villadi/images/header) [function.opendir]: failed to open dir: No such file or directory in /home/monticog/wwwroot/domainname.com/modules/mod_ja_header/mod_ja_header.php on line 69
    Warning: readdir(): supplied argument is not a valid Directory resource in /home/monticog/wwwroot/domainname.com/modules/mod_ja_header/mod_ja_header.php on line 71
    I could find nothing on line 69 of mod_ha_header.php to indicate a problem.
    Then, I opened mod_ja_header.xml, and sure as heck, on line 29, it reads:
    <param name=”ja_header_folder” type=”text” default=”templates/ja_villadi/images/header” label=”Image folder” description=”Folder to display image” />
    I changed the “ja_villadi” to read “ja_antares” and the problem went away.
    I just thought you would like to know that so that you can update your distribution package accordingly.
    alliedvoa Friend
    #267505
    They still haven’t fixed this problem for those of you downloading and installing as above. :confused:
    #267611
    sorry, I will update now
This topic contains 3 replies, has 3 voices, and was last updated by  Sherlock 16 years, 4 months ago.
