  • mrogers2010 Friend
    #154677
    I am trying to turn on the “Search Engine Friendly URLs” setting in Joomla 1.5 under the Global Configuration area on my website. When I do that, the URLs are changed but the JA_Helio template does not work. All of my pages become text without any formatting. Is this a problem with the template or do I need to do something else to make it work?
    Phill Moderator
    #356836
    Have you renamed htaccess.txt to .htaccess in the joomla root?
    Does it also fail if you set a different template as default?
    mrogers2010 Friend
    #356849
    <em>@phill luckhurst 195720 wrote:</em><blockquote>Have you renamed htaccess.txt to .htaccess in the joomla root?
    Does it also fail if you set a different template as default?</blockquote>
    Hi Phil,
    Thanks for the help. Yes the problem did exist with other templates. Your suggestion to look at the .htaccess file worked! My Web Server provider is using Apache and I had to comment out the line that is listed in the HTACCESS.TXT file concerning “Options +FollowSymLinks”, and then turn on both “Search Engine Friendly URLs” and “Use Apache mod_rewrite” to get everything to work.
    Thanks again!
This topic contains 3 replies, has 2 voices, and was last updated by  mrogers2010 14 years, 3 months ago.
