  • Tran Anh Dung Friend
    #129972
    Hi!
    I use “ja_mageia_template_v1.2_1.5.3.zip” with Joomla! 1.5.1 and I have two problem:
    1. when user use Login Form to register, after fill the form and click on “Register”, do not display communicate “Your account has been created and an activation link has been sent to the e-mail address you entered. Note that you must activate the account by clicking on the activation link when you get the e-mail before you can login.”, and some other communicates when user use Login Form do not displayed too.
    2. pages not correct display on Mozilla Firefox.
    Can you help me?
    Thanks a lot
    Tran Anh Dung
    #255731
    Hi Dung !
    You can fix the problem following way below:
    on index.php file in templates/ja_mageia folder, find follollowing code line :
    <jdoc:include type="component" />
    Change to :
    <jdoc:include type="message" />
    #255803
    Hi hainn84,
    Thank you very much hainn84 ! I do exactly as you show me and well done!
    Best regards
    Dung
This topic contains 3 replies, has 2 voices, and was last updated by  Tran Anh Dung 16 years, 5 months ago.
