  • gille30093 Friend
    #129805
    I have an issue with the component. The autoresize feature works correctly, but it only resizes the pictures after the first one. So basically the irst image is not resizes, only the ones after it. This looks pretty bad when you try to display images in the module that are much smller than the area…
    #254328
    Hi gille30093 !
    I don’t understand your issue. I have try but couldn’t reproduce this isusse. Size of first image always is same size with others image.
    Menalto Friend
    #254340
    When you load the page, the first image is normal size, after a few seconds it starts to rotate and the images is rezised.
    If you set the slideshow to 400px 400px and use the imags/stories/food folder you see it very good.
This topic contains 3 replies, has 3 voices, and was last updated by  Menalto 16 years, 5 months ago.
