July 15, 2015 at 2:25 pm #208791
Hi Team!
I have problems with JAC galery Links in style 2, these links are not reaching the target site and do not know why. C
When you click on these images show only the home page, but if you look at the address bar see that clearly identifies the link destination.
Can you help me?Pankaj Sharma ModeratorPankaj Sharma
July 16, 2015 at 2:30 am #577562Hello
It seems the template style you are using on the menu item propuestas does not contain the component block , so its not showing the item . Try to change the template style and check ,
I tried to check it on your admin panel but admin. login page is Forbidden for me .Pankaj Sharma ModeratorPankaj Sharma
July 16, 2015 at 2:30 am #643859Hello
July 16, 2015 at 2:30 am #742506Hello
I tried to check it on your admin panel but admin. login page is Forbidden for me .July 17, 2015 at 2:49 am #577739Dear pankajsharma, I am not able to fix it, could you help me? I step by private message to the administrator access
regards
sergiospPankaj Sharma ModeratorPankaj Sharma
July 17, 2015 at 3:01 am #577741Hello I tried to check it on your admin panel but admin. login page is Forbidden for me .> http://prntscr.com/7tmo7e
Please temp. remove the security from site so i can check it .July 17, 2015 at 1:59 pm #577832Dear Friend,
already enabled the administrator, we had server problems, apologize for the inconvenience
sergioJuly 17, 2015 at 1:59 pm #644126Dear Friend,
sergioJuly 17, 2015 at 1:59 pm #742761Dear Friend,
sergioPankaj Sharma ModeratorPankaj Sharma
July 19, 2015 at 8:13 am #577874Hi
Kindly check it again . its forbidden for me >> http://prntscr.com/7ue89l
Update me once this issue is fixed so i can check it.I also the issue is fixed on your site > http://prntscr.com/7ue94j , Now the articles are not opening on homepage.
This topic contains 11 replies, has 2 voices, and was last updated by sergiosp 9 years, 3 months ago.
