  • vernontee Friend
    #952220
    If we take a look here
    http://rapidfy.com/united-states/cleaning-services/courtney-s-home-cleaning
    and click on the location here
    http://screenpresso.com/=VwqWf
    …say United States, It will bring you to
    http://rapidfy.com/jak2filter?xf_2_txt=453
    which is a blank page.
    If i click on the author link on the other hand, it will send me to a broken link.
    Why is this occuring?
    Thanks.
    Luna Garden Moderator
    #952291
    vernontee Friend
    #952680
    #952805
    The Page is blank cause of JA Directory style Feature doesn’t show component on Front-end. Meanwhile, your site using SH404, and all link of JA K2 Filter is redirect to Homepage. So I just set SH404 ignore JA K2 Filter.
    You can check on your site, Location is loading to new page with content now.
    vernontee Friend
    #953224
    Any chance you know why the UI is a litle screwed when i click on the state filter link/
    http://rapidfy.com/component/jak2filter/?xf_2_txt=411
    http://screenpresso.com/=NItqb
    also is it possible to rename "component/jak2filter" to something else of my own needs. like just the word "search"
    #953326
    I just changed the setting in Backend >> JA K2 filter >> Option >> Item View Option >> set to Hide Author and Date Created.
    No, it’s impossible. It relates to the workflow of JA K2 Filter and the ability to update newer version of this extension.
    vernontee Friend
    #955376
    Now i get a different problem…
    1) in the search page… the orange pop up content is empty… but all info is there .. just not shown.. and only in the search page.
    2) How do i assign a module in the search results page… the one with "jak2filter" in the URL? Its showing a module that i dont want shown (i.e. my custom search bar)
    vernontee Friend
    #955377
    #955553
    Go to backend >> JA K2 filter Option >> Item View Options >> Set to show Extra Field.
    Just assign it to appear on all page, Page that has "jak2filter" is not assigned to any menu item, so it’s hard to Assign module too.
    vernontee Friend
    #958193
    What does "update indexing data" button do? What data is it updating and when do i need to press it?
    vernontee Friend
    #958194
    If you look at this…
    http://screenpresso.com/=hn3Kc
    Do notice that the orange slider position is a little off…. its lower than it should be.. this happens in search pages.
    #958238
    This option is to update the total number of items for each Extra field, make searching faster.
    Update indexing each time you upgrade, or change/add new K2 Item. You can set JA K2 Filter update automatically by go to: backend >> Component >> JA K2 Filter >> Option >> Update Indexing, set Update indexing Event to Yes, set Update indexing Cron to Yes, & set Update Indexing Interval time.
    You can search more about this setting in our document: https://www.joomlart.com/documentation/joomla-component/ja-k2-filter#com-config
    It’s because of setting show the Intro Text, just go to backend >> Component >> JA K2 Filter >> Item View Option >> Set to hide Intro Text.
This topic contains 11 replies, has 2 voices, and was last updated by  Luna Garden 8 years, 4 months ago.
