  • gothik Friend
    #136382
    I am facing a problem with janews extension. When I made a post to my site with image it comes with this error messages.
    Warning: getimagesize(/home/myhost/public_html/images/stories/brad-pitt-and-angelina-jolie-0508-2.jpg) [function.getimagesize]: failed to open stream: No such file or directory in /home/myhost/public_html/modules/mod_janews/helper.php on line 74
    Warning: Division by zero in /home/myhost/public_html/modules/mod_janews/helper.php on line 84
    Warning: Division by zero in /home/myhost/public_html/modules/mod_janews/helper.php on line 85
    Warning: imagecreatefromjpeg(/home/myhost/public_html/images/stories/brad-pitt-and-angelina-jolie-0508-2.jpg) [function.imagecreatefromjpeg]: failed to open stream: No such file or directory in /home/myhost/public_html/modules/mod_janews/helper.php on line 116
    Warning: imagecreatetruecolor() [function.imagecreatetruecolor]: Invalid image dimensions in /home/myhost/public_html/modules/mod_janews/helper.php on line 126
    Warning: imageantialias(): supplied argument is not a valid Image resource in /home/myhost/public_html/modules/mod_janews/helper.php on line 128
    Warning: imagecopyresampled(): supplied argument is not a valid Image resource in /home/myhost/public_html/modules/mod_janews/helper.php on line 129
    Warning: imagejpeg(): supplied argument is not a valid Image resource in /home/myhost/public_html/modules/mod_janews/helper.php on line 130
    Please help me to get rid of this error.
    sunrise Friend
    #283556
    Do you have a url or more info that might help, Joomla version, etc?
    gothik Friend
    #283559
    Sent you a PM with my web URL.
    sunrise Friend
    #283564
    Thanks. I looked at it and seem to remember something similar happened to me. The only thing I can think of off hand is that there is nothing in the movies link. All the other links work fine, but not that one.
    It says::: Division by zero in… so maybe it has nothing to work with, no articles or pics. Another problem I had once, was that the pictures I used were too big. I had to reduce the file size. I don’t know if this is a help. Hope it is.
    sunrise Friend
    #283565
    Looking a bit closer I see that you do have some articles and pictures there, so that is maybe not the problem. It seems to be in the one picture
    I’ll do some more research and try to find a solution to your problem, or someone else will.
    Joost Buntinx Friend
    #302157
    i have the same issue , was there any solution?
    zentering Friend
    #302658
    Hi all!
    Have the same problem, any solution?
    / Z
    #302765
    noty yet 🙁
    jagdambasoft Friend
    #357526
    Read 12-20-2008 06:01 AM
This topic contains 9 replies, has 5 voices, and was last updated by  jagdambasoft 14 years, 2 months ago.
