  • kattaweb Friend
    #131222
    Hello everybody,
    I have a problem with the Ja_slideshow module: when I place it in the right column, it doesn’t go but if I put it in another position it go. How can I do to understand what is the problem?
    Someone has have the same problem?
    Thank you and sorry for my bad english
    Lucie
    Menalto Friend
    #262227
    Did you manage to get this solved yet? If you did please mark this as solved, if not let us know.
    kattaweb Friend
    #262239
    I don’t solved this problem, so if you have a solution…:D
    Thank you
    kattaweb Friend
    #262663
    Goodmorning,
    i’ll try to explain my issue with mod_jaslideshow using Ja Labra template.
    If I place the module either in left or right position the module does’nt work correctly ( only the first image apper and nothing else happens ).
    If I switch to Ja Purity or Ja Iolite templates ( for example ) the module works properly.
    If I switch back to Ja Labra and change the position of the module to user5 position the module works properly again.
    It seems to me there is a kind of bug related to Ja Labra template using mod_jaslideshow in left or right position.
    You can find an example at the following url http://demo1.cnademoarea.it
    Thank you very much,
    Marco
    Menalto Friend
    #262680
    Going to test out and see if i can get same error here.
    geekyartist Friend
    #280419
    I have been testing out ja labra and when I switch off coverflow and turn on jaslideflow the first photo comes up but it does not cycle through the photos!
    Has this been resolved?
This topic contains 6 replies, has 3 voices, and was last updated by  geekyartist 16 years, 1 month ago.
