  • eddy2009 Friend
    #160288
    after the quick installation (Templ. “Portfolio”, I have the following error message:
    Parse error: syntax error, unexpected ‘)’, expecting ‘(‘ in ……/plugins/system/jat3/core/common.php on line 230
    According to the provider, it is not the php version. The provider has 4.4.9.
    There is a syntax error and therefore it is a script error.
    Now what is wrong?
    Thanks for the help.
    Khanh Le Moderator
    #377277
    Hi eddy,
    Please kindly update your site information into ticket PVR-461-18634 and reopen the ticket, our technical support will check and give you solutions to fix the problem.
    You can access the ticket by visiting our support site http://support.joomlart.com, then login with your JoomlArt account.
This topic contains 2 replies, has 2 voices, and was last updated by  Khanh Le 13 years, 11 months ago.
