  • shan_mm Friend
    #176503
    i have recently installed elastica template and jat3 framewwork. But i get the following errors on my administrative:
    Strict Standards: Only variables should be assigned by reference in C:xampphtdocsjoomlapluginssystemjat3jat3.php on line 41
    Strict Standards: Declaration of JParameter::loadSetupFile() should be compatible with that of JRegistry::loadSetupFile() in C:xampphtdocsjoomlalibrariesjoomlahtmlparameter.php on line 512
    Strict Standards: Only variables should be assigned by reference in C:xampphtdocsjoomlapluginssystemjatypojatypo.php on line 55
    Strict Standards: Non-static method T3Common::get_active_template() should not be called statically in C:xampphtdocsjoomlapluginssystemjat3jat3coredefine.php on line 16
    Strict Standards: Non-static method JAT3_AdminUtil::get_active_template() should not be called statically in C:xampphtdocsjoomlapluginssystemjat3jat3corecommon.php on line 66
    Strict Standards: Non-static method JAT3_AdminUtil::checkPermission() should not be called statically, assuming $this from incompatible context in C:xampphtdocsjoomlapluginssystemjat3jat3.php on line 161
    Strict Standards: Non-static method JAT3_AdminUtil::checkCondition_for_Menu() should not be called statically, assuming $this from incompatible context in C:xampphtdocsjoomlapluginssystemjat3jat3.php on line 163
    Strict Standards: Non-static method T3Common::detect() should not be called statically, assuming $this from incompatible context in C:xampphtdocsjoomlapluginssystemjat3jat3.php on line 183
    Strict Standards: Non-static method T3Path::path() should not be called statically, assuming $this from incompatible context in C:xampphtdocsjoomlapluginssystemjat3jat3corecommon.php on line 52
    Strict Standards: Non-static method JAT3_AdminUtil::checkCondition_for_Menu() should not be called statically, assuming $this from incompatible context in C:xampphtdocsjoomlapluginssystemjat3jat3.php on line 68
    Strict Standards: Non-static method T3Common::detect() should not be called statically, assuming $this from incompatible context in C:xampphtdocsjoomlapluginssystemjat3jat3.php on line 85
    Ans again the following error on my site:
    on header area:
    Strict Standards: Non-static method T3Common::detect() should not be called statically, assuming $this from incompatible context in C:xampphtdocsjoomlapluginssystemjat3jat3.php on line 200
    then a few more errors down the page:
    i have tried eding the php.ini file but inn vain!
    HeR0 Friend
    #450472
    Please add [PHP]error_reporting(E_ALL & ~E_STRICT); [/PHP] to header of index.php file ( in template )
This topic contains 2 replies, has 2 voices, and was last updated by  HeR0 12 years, 8 months ago.
