  • _seia_ Friend
    #177821
    I install Joomla and than i install the template, than i isntall the JAT3 plugin.
    i have this problem:
    Strict Standards: Only variables should be assigned by reference in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3.php on line 41
    Strict Standards: Declaration of JParameter::loadSetupFile() should be compatible with that of JRegistry::loadSetupFile() in /kunden/293897_10559/webseiten/Patiententransport/libraries/joomla/html/parameter.php on line 512
    Strict Standards: Non-static method T3Common::get_active_template() should not be called statically in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3/core/define.php on line 16
    Strict Standards: Non-static method JAT3_AdminUtil::get_active_template() should not be called statically in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3/core/common.php on line 66
    Strict Standards: Non-static method JAT3_AdminUtil::checkPermission() should not be called statically, assuming $this from incompatible context in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3.php on line 161
    Strict Standards: Non-static method JAT3_AdminUtil::checkCondition_for_Menu() should not be called statically, assuming $this from incompatible context in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3.php on line 163
    Strict Standards: Non-static method T3Common::detect() should not be called statically, assuming $this from incompatible context in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3.php on line 183
    Strict Standards: Non-static method T3Path::path() should not be called statically, assuming $this from incompatible context in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3/core/common.php on line 52
    Strict Standards: Non-static method JAT3_AdminUtil::checkCondition_for_Menu() should not be called statically, assuming $this from incompatible context in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3.php on line 68
    Strict Standards: Non-static method T3Common::detect() should not be called statically, assuming $this from incompatible context in /kunden/293897_10559/webseiten/Patiententransport/plugins/system/jat3/jat3.php on line 85
    what can i do?
    1. Unbenannt-2
    HeR0 Friend
    #456049
    Hi Seia
    Please follow at topic http://www.joomlart.com/forums/topic/errors-strict-standards-non-static-method-t3common/ to get solution for your issue.:)
    Regards,
    _seia_ Friend
    #456096
    that all not work…:((
    HeR0 Friend
    #456218
    Hi Sela
    Did you edit index.php to
    [PHP]<?php
    // no direct access
    defined ( ‘_JEXEC’ ) or die ( ‘Restricted access’ );
    error_reporting(E_ALL & ~E_STRICT);
    if (class_exists(‘T3Template’)) {
    $tmpl = T3Template::getInstance();
    $tmpl->setTemplate($this);
    $tmpl->render();
    return;
    } else {
    //Need to install or enable JAT3 Plugin
    echo JText::_(‘MISSING_JAT3_FRAMEWORK_PLUGIN’);
    }[/PHP]
    Regards,
This topic contains 4 replies, has 2 voices, and was last updated by  HeR0 12 years, 6 months ago.
