  • 2377 Friend
    #180934
    Problem with JAT3 Clean Cache
    Hi , I have a big trouble, I manage a site with a JA Teline IV with joomla 2.5, and when I want to update a youtube video I need to clean JAT· Clean Cache and have a error (I send and image) .
    I create a php.ini file with :
    memory_limit = 64M;
    But , it´s the same error.
    Can you help me please.
    1. Captura
    Ninja Lead Moderator
    #468073
    What cache did you config on your site? I saw “php.ini” file on /libraries/joomla/cache/storage with “memory_limit 128M” but your hosting is configured as “memory_limit 32M”. Please expand memory_limit from “32M” to “128M” and test again. I have disabled cache JA Template on your site and this problem is not depended on JA Template cache( JA Template is using default cache with JOOMLA CORE)
    2377 Friend
    #468131
    Thanks for your help!!!! 🙂
    I expand to 128m and looks well, it´s ok
    JAT3 Clean Cache is disabled, I can upload articles and then save, I don´t need to clean cache, because the changes are directly,
    If a click clean cacher the error is present, are there any problem if JAT3 Clean Cache is disabled?
    Thanks again
    #468194
    <em>@2377 339707 wrote:</em><blockquote>Thanks for your help!!!! 🙂
    Thanks again</blockquote>
    Re-check on your site i saw back-end your site “memory_limit is still 32M”. About JAT3 Clean Cache and system cache on JOOMLA CORE is the same.
    I could not access to Cache on joomla
    <blockquote>Admin area->Site->Maintenance->Clear Cache and you see show the same with click “JAT3 Clean Cache”</blockquote>
This topic contains 4 replies, has 2 voices, and was last updated by  Ninja Lead 12 years, 3 months ago.
