  • cyllenius Friend
    #146273
    Website where problem is occurring: http://www.istitutobolisani.it
    – Joomla 1.5.15
    – Jomsocial 1.5.248
    – Ja Purity II v 1.1
    – Internet Explorer 6-7-8
    Problem:
    When a user is logged in in Jomsocial and goes to the profile page, the dropdown menus are not shown and menu items appears as a list.
    Any idea?
    UPDATE: the problem is resolved in IE8 if “compatibility view” is turned off
    tgotch64 Friend
    #326679
    Do you have a test login?
    dangdai Friend
    #326709
    you can click “User CP” to see the profile.;)
    eolgeorge Friend
    #331059
    I have the same issue here-
    http://thevillagegardeners.com
    Specifically on-
    http://thevillagegardeners.com/index.php/eolcommunity.html
    Any thoughts appreciated.
    TIA,
    G
    eolgeorge Friend
    #332093
    It apears that Purity II is also breaking the log in module of JomSocial.
    Any Ideas-
    http://piratesofpointlookout.com
    G
    bryantwest Friend
    #332094
    Could it be another issue with Mega Menu? Again?… possibly?… if your issue is with Mega Menu… man it’s a DUD. Try PMing http://www.joomlart.com/forums/member.php?username=phill luckhurst
    He seems to be on to it when it comes to menu issues
    eolgeorge Friend
    #332097
    Thanks for teh reply.
    Definately the mega menu, everything worked fine with the other menus that came with the template. Decided to go with one of those instead.
    Cheers,
    G
This topic contains 7 replies, has 5 voices, and was last updated by  eolgeorge 14 years, 11 months ago.
