  • ezaban Friend
    #196468
    After configuring the jomsocial, we just change the homepage of our website to the frontage of Jomsocial.
    When we turn on the Native joomla Search Engine Optimization, the template will not be load and we cannot see any module. Everything appears to be ruined.
    We use Ja-Branis template from Joomlart.
    When we turn the native SEO feature off, it works perfectly.
    Please help us how we can solve this problem because using SEO feature is essential for us.
    Do you recommend Sh404SEF instead of native joomla SEF feature?
    Thank you,
    Pankaj Sharma Moderator
    #529612
    <em>@ezaban 420014 wrote:</em><blockquote>Hello,
    Thank you,</blockquote>
    hi @ezaban
    i just checked your site.
    we will not Recommand you sh404 or any other plugin.
    system SEF plugin is default plugin provided by joomla and you should use it.
    i found the System SEF plugin is enabled On your site.
    and site is working fine.
    did you solve the issue??
This topic contains 2 replies, has 2 voices, and was last updated by  Pankaj Sharma 10 years, 8 months ago.
