  • kyovev Friend
    #170853
    Hello, my jomsocial does not work very well when i turn on join&minify&compress.
    Would you please look at this HD video?
    http://www.youtube.com/watch?v=5iMZQiT3tjI
    which jomsocial files should i exclude from cache to fix this?
    kyovev Friend
    #425472
    Add new item in k2 was not working too and i added k2.js and now it works fine. For jomsocial i added this in the optimize exclude field the following files:
    jomsocial
    joms.jquery.js
    jquery.min.js
    they probably are not the right files…. so which are the right files? Is there any way to fix k2 add item without disabling k2.js from compress?
    kyovev Friend
    #425578
    Anyone? I really need to solve my problem with jomsocial…
    Phill Moderator
    #425955
    K2 uses a different js library to Joomla so you cannot compress it with the Joomla files.
    kyovev Friend
    #425967
    I added k2.js to my Optimize Exclude and now it seems to work fine 🙂
This topic contains 5 replies, has 2 voices, and was last updated by  kyovev 12 years, 12 months ago.
