  • KaemikhaRungrojvisai Friend
    #149236
    i install this template with jomsocial, only 1 problem is at mystatus when i click to fill wording the submit button not come up as joomla standard template. but at the hellome module can update mystatus as well.
    please help
    my best template site ( design + service ) : 😀
    kaemikha
    #335159
    today i try to check again with my site install problem by uninstall module and check it. and when i uninstall Gtranslate from my site the problem that i have will ok.
    Dear KaemikhaRungrojvisai,
    I need the confirm from you, have you any problems with the template? if have, pls give me the link to your site 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 14 years, 8 months ago.
