  • rramirezech Friend
    #129936
    Help me please, I try to install this templete, and appears this error:
    Upload template – Upload Failed
    ERROR: Could not find an XML setup file in the package.
    [ Continue … ]
    Upload template – Failed
    Installation file not found:
    /home/wwwmisi/public_html/media/install_485bdd9b4f586/
    [ Continue … ]
    What happends???
    Regards,
    Roberto
    nathanbohn Friend
    #255005
    make sure your folders are writable. You may need to make them all temporarily 777 to install it, then chmod them back to 644
    rramirezech Friend
    #255039
    oooh man !!!! So Sooooorryyy !!!
    I’m try to install the .zip file ja_galena_v1.0……
    And the install file it´s ja_galena_1.0_templates.zip Inside the file
    I´m sorry, jajajaja
    Thanks a lot
    nathanbohn Friend
    #255048
    glad it was simple to fix
    #255107
    Goog luck to you
    Plz mark your topic is solved when your problem is fixed
This topic contains 5 replies, has 3 voices, and was last updated by  Sherlock 16 years, 6 months ago.
